Hi
Have just installed the upgrade card for the Leap Frog 96 but we are having issues with getting it to work.
The desk is receiving the timecode signal but the cues seem to just jump around and every time we run the timecode it jumps around in a different order. It also seems to make no difference if midi timecode is enabled or disabled it still jumps around even when midi is switched off! :unsure:
We have tested the midi lead, midi box & software on the MD's Pit computer and it is working fine.
The other worrying problem i have is since installing the card the led flash buttons on channels 13-24 & 61-72 are all ways on from boot up?!?
and the final issue i am having is the desk dose not always boot first time, sometimes takes 3 attempts to get it to boot, dose anyone else have this problem?
Can any one help??
Thanks in advance
Richie
Hi Richie,
think I spoke to you this morning if not then please drop me a mail or call the dd number below.
Keith Rogers
