Sign in to follow this
GLX
Duplicate Fixture patching
Is there any chance of been able to patch multiple fixtures to a fixture button WITH OUT changing their addersses, ie.. was in a club for a three night stint using house dmx run(too lasy to run mine!) and instead of rerouting the house dmx from foh back to the twit box(dj) could have been easier to patch all their fixtures to the fatfrog and push the magic frog button :?
Do you mean the ability patch a single fixture to several different DMX start addresses, in the same way that generic channels can be patched to up to 10 different DMX addresses.
If so, then this is something we will be looking into. :wink:
If not, then please explain further 8O
What's the chance of being able to patch more than one fixture to a fixture button?, of course the fixtures would have to be of the same type, max of four or something like that, is it a big job to do this :?
Why?
There are some solutions; if you want the fixtures to act exactly the same (thats what I get from your question...) just make them listing to the same DMX address, that works just fine.
If that's not the case; you could always write a fixturefile and copy the parameters. But beware; all of your menus will be copied too, so one fixture button will contain 2 colour selections, 2 gobo etc if you place 2 fixture there. I think that would suck bigtime :)
Whats your problem? (Why do you want to do this???)
Using a fatfrog, got ten martin kryptons of my own, a venue i'm gigin in soon has mini scans just would like to option of patching all the scans to one fixture button.Can invert the pan on the mini scans so it'll look ok.
Currently on the frog series of desks you can patch a generic channel to a maximum of 10 different DMX channels, but a fixture can only be patched to one DMX start address.
This has been raised as an issue, particularly on the Mambo Frog since it does NOT have generic channels in the same way that the other desks in the Frog series have.
It is of course possible to assign a single brightness channel fixture (dimmer) to the fixture buttons on the mambo frog but it will then be treated as a FIXTURE and therefore cannot be patched to multiple DMX addresses ... at the moment.
One of the things we are considering for a future release is to allow fixtures to be patched to multiple DMX addresses as well as generic channels.
Is it possible for the Mambo Frog to control mutiple dmx channels with one parameter ?
Here is the story:
I have 12 led globes, controlled by a 48ch controller (4 channels per globe: brightness, colour, fx & fx speed).
The controller only knows the starting address, and adds up the addresses internally.
My globes are grouped together by 3, these 3 (12 dmx channels) need to be controlled together. Meaning the brightness needs to control 3 addresses , the colour 3 and the beamshape 2x 3 addresses, resp. for each globe in the cluster.
I tried the add sub fixture in the fixture editor, but this doesn't solve my problem.
I can't assign them speratly to a fixture, for the simple reason that I'm running out of fixtures.
Short:
One assigned fixture on the frog, needs to be set to 3 dmx addresses
Any ideas ?
