james Posted November 11, 2010 Report Posted November 11, 2010 SOOOO heres the thing is this possible cue 1. blackout cue 2. 3 sec fade up on Cyc with night time look cue 3. 2min fade of cyc to day time look cue 4 DS lights up 10seconds into Cue 3 running Cue 5 US lights up 40 seconds into cue 3 running Effectively Cue 3 programmed with seperate lights to cue 4 and 5 but cue 3 running to its fade time while the cue stack continues on its merry way I assume that with tracking if cyc channels are not given another command they will not do anything different but will the fade times get cut off I am aware that other desks from other manufacturers etc. <--- hint have this element/function called Move-fade that seems to suggest this very thing is possible ^ | hint Is it possible on the ZEROS desks Cheers James Dainty Quote
Jon Hole Posted November 12, 2010 Report Posted November 12, 2010 I assume that with tracking if cyc channels are not given another command they will not do anything different but will the fade times get cut off Looks like you're going to have to turn Tracking back on, doesn't it James You are right, as long as the lanterns from the previous cue aren't involved in the next cue, they won't get affected, and will continue with their fade, even if you GO with the next cue. Quote Jon Hole Global Product Manager, Systems and Control
james Posted November 12, 2010 Author Report Posted November 12, 2010 As i speeak im just turning the desk into tracking mode And after some very good training from yourself Jon i'm haoppy to do so and know how to avoid those annoying little problems. Glad this works its going to be very handy. Cheers again Jon was a good days training. see you soon perhaps. James Quote
