Kresten Bager Posted November 11, 2010 Report Posted November 11, 2010 Hi all! I'm doing a show tomorrow where I'll be using 24 Jarag fixtures. Does anyone know if you can make a fixture profile for this fixture? I'll need 25 dimmer ch. and 6 'beamshape' parameters, can this be done? If not any thoughts on how to use this fixture - I cannot patch 744 dimmer ch. as there are not enough MFK's The fixture is described here: http://www.chromlech.fr/media/support/manuels/userguide_revD_full_eng.pdf Best regards Kresten Quote Kresten Bager Polyteknisk Scenelys www.scenelys.dk
Jon Hole Posted November 12, 2010 Report Posted November 12, 2010 Hi Kresten, I have just made the fixture personality for you - please find it attached. I hope this helps. Jarag.iftFetching info... Quote Jon Hole linkedin.com/in/jonhole
Kresten Bager Posted November 21, 2010 Author Report Posted November 21, 2010 Hi Jon, Thanks for the profile - I'll give it a try! Best regards Kresten Quote Kresten Bager Polyteknisk Scenelys www.scenelys.dk
