Hello
We Have our fire alarmed patched into our chilli dimmers. At the moment when the alarm comes on all the dimmer channels come on.....
Is it possible to set it so a scene is loaded, or disable certain channel from coming on in the event of alarm being set off?
I need a new job
Hi Kev,
At the moment, when the alarm is activated, the chilli's take all channels to 80%.
If you want to replay a scene memory, you need a 'Chilli Net Bridge'. This connects between the Chilli and the Fire Alarm, so you connect the fire alarm to the Chilli Net Bridge, and then the Net Bridge of the Chilli itself. The part number for this is 01-210-00.
Hope this helps,
