dantheman1707 Posted November 8, 2010 Report Posted November 8, 2010 Hello,Can anyone help me,the fade up and fade down time always go back to snap,is there anyway you cna set the fade up and fade down time to 3seconds and it will always stay like this??thanks!! Quote
Jon Hole Posted November 8, 2010 Report Posted November 8, 2010 Hi Dan, Are you pressing 'EDIT' before changing the time, and then pressing 'EDIT' again after to confirm this? Once you have recorded a cue, you have to be in 'EDIT' to make any changes, including the fade times. It is possible to change the fade time before recording a cue or submaster too. Cheers Quote Jon Hole linkedin.com/in/jonhole
