darkness Posted October 25, 2010 Report Posted October 25, 2010 I have a strange problem in that whenever i try to access the floppy drive, even with no disk in the drive the console turns off for a couple of seconds and then reboots. I've not known a floppy drive to reboot a machine (be it a lighting desk or computer) when its faulty, they normally just cant read disks. Is this likely to be a bad floppy disk drive or a more serious problem, i don't have any working disk drives to try and would like to know this will fix it before i go and buy one. Quote
KWR88 Posted October 26, 2010 Report Posted October 26, 2010 That sounds like a problem with the PSU going into reset when the drive is accessed. This could indicate a problem with the PSU. Try measuring the 5v rail and see what its level it is at. It could also indiacte a problem with the drive motor over drawing. It might be be a case of things right on the edge of their tolerance. The drive is drawing a little more than it used to due to age etc, the PSU over load sense circuit is right on the edge. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
