Endorphin69 Posted October 15, 2010 Report Posted October 15, 2010 Have just created the itf file for Lanta Fireball64 led parcans. Read all the manuals on the fixture editor and set the colours as red + green+ blue+. That's what shows up in the fixture editor. Once transfered to the Orb and the desk is restarted, the fixture shows as cmy instead. I know this won't affect the colour picker but the labelling on the control wheels is causing confusion with the students (and myself). Hope someone can help. Cheers B Quote
Jon Hole Posted October 15, 2010 Report Posted October 15, 2010 The ORB allows you to choose which method (CMY or RGB) you wish to work in. This is most useful when working with RGB and CMY fixtures together, as you can just mix using one colour space and the desk will automatically convert that information for alternative fixtures. To change from CMY to RGB, hold down SETUP and press the COLOUR attribute button. This will bring up a window with three buttons. Click 'Colour Edit Mode' and choose if you want to work with CMY or RGB on the wheels. Hope this helps, Quote Jon Hole linkedin.com/in/jonhole
Endorphin69 Posted October 15, 2010 Author Report Posted October 15, 2010 Works a treat. Thanks for your help. Quote
