abel_bcn Posted September 21, 2010 Report Posted September 21, 2010 Hi, yesterday was my first day working on a new club, I've been working on a fat frog for a year or so and in my new work they have a fat frog too. I wanted to make some chases with the lights, everything went ok until I tryed to playback them, they were shown in the output panel as working but lights were not working. Software was old, 5.4 or so (table said 2004 bios) I'll try to update tomorrow, but I don't know if I'm missing something in the superuser menu or how can I solve this problem, it's a bit annoying. Also, tranfer with time and transfer without time buttons didn't work, I had playback X master at 100% and Grand master too. Any Ideas? Thanks a lot, you're doing a good job with your tables Quote
KWR88 Posted September 21, 2010 Report Posted September 21, 2010 Not aware of any issues with either the chase or cue transfer functions on that version of the OS. I would run the update and retry the desk to see if this does cure the problem. It may also be worth running the front panel test. PM me on the address below and I will pass the information on for you. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
abel_bcn Posted September 21, 2010 Author Report Posted September 21, 2010 I'm from Barcelona (Spain) tonight will try to update desk, and see if improves. If persists I'll try to contact you. Thanks a lot! PS: How can I perform a Front Panel test? Quote
Jon Hole Posted September 21, 2010 Report Posted September 21, 2010 If you email Keith, he will email you the instructions to do this. Quote Jon Hole linkedin.com/in/jonhole
abel_bcn Posted September 21, 2010 Author Report Posted September 21, 2010 Thanks Jon, I understood he told me to write my location so he could tell me where I should bring the table if problem persists. Nightlife is killing me Quote
