Hi!
I am a newbie in this matter, so i decided to ask.
Is it possible to upgrade JesterML 24 version 2.0 to 3.0 and does it reset the whole desk (clears the presets and fixture libraries) if it does, then is it possible to make backup?
Fast help is appreciated.
Thanks for advance
Peeter
Hi Peeter,
It sure is.
First, take a backup to USB. This is done through super user, and is explained on page 45 of the manual, available here:
http://common.zero88.com/public/files/7340600_JesterML_Manual_3_0.pdf
Then, download the software from here onto a USB stick:
http://support.zero88.com/main/en/product/89
There are instructions on how to do this here:
http://common.zero88.com/public/files/JesterSoftwareUpdateInstructionsIssue3.pdf
Once you have done this, you can reload your show from the original USB stick, also through super user.
Hope this helps,
Jon Hole
