how do i connect a leap frog 48 up to a wifi network that already exists, then connect my iphone to the desk over the same network so i can use the new iphone app that has just been released for remote use with this desk??
andrew
Hi Andrew,
You will need to connect the desk via an ethernet router to the network.
However, I would suggest setting up a separate network for the console for security and reliability. Any wireless DCHP router will work, and these can be picked up for around £30 from your local computer store - probably less. These just plug straight into the back of your console with the ethernet cable usually provided with the router.
I hope this helps?
