Bilderbuch Posted August 24, 2010 Report Posted August 24, 2010 Hi, is it possible to create an effect that i can record to a submaster which then controlls the size of the effect? For example: Sine on Tilt with no speed and no size asigned recorded to submaster 1.1 So the position of the submasterfader controlls the size and a second submaster should controll the speed. When i record an effect with sine on tilt, speed set to 20 and size to 20 then record it to a submaster and tell the submaster to controll effects then i can only controll the speed with the position of the submaster. Is this kind of programming possible? Regards Torsten Quote
Jon Hole Posted August 24, 2010 Report Posted August 24, 2010 Hi Torsten, Sorry - It's not yet possible to split effects across Submasters in ZerOS. Quote Jon Hole Global Product Manager, Systems and Control
