Have recently acquired a Jester 12/24 (updated to Vers 3.4). Seems to function perfectly, as does Phantom Jester (vers. 3.1) running on Vista. Jester will save, load and erase ok, as does Phantom. But I cannot save on one and load to the other. It simply says "No Shows on Disk", if I save on Jester and try to load onto Phantom and vice versa, even though this is not the case.
When you first open Phantom Jester, click settings, and then Browse to your USB as the 'local' drive.
You'll probably find at the moment it is saving, and trying to open, files on your local hard drive instead of the USB.
As the Jester doesn't have support for multiple directories at the same time, you have to change it here first.
Hope this helps.
