5.4.0 Total Reset
Marc Fleming
Hi Marc,
Sorry you've been having problems.
I can't find any other reports of this problem on our systems.
If you create a new show, and turn off / on the desk, do you loose that new show?
Cheers,
Jon Hole
Hi Guys,
The new ZerOS software is not fully supported on the older Frog 2 consoles, as the hardware can't support it all.
There are two options to fully run 5.4: there is an upgrade kit available to replace the hardware inside the desk, or alternatively it's time to look at replacing the desk to a newer generation Frog 2, Leap Frog or ORB (soon, ORB XF).
Your local dealer can give you more information, including prices, for both these options.
Cheers
Jon Hole
Hi All,
I have the same problem on a Leap 48.
Every time I turn it on it's like I've done a full desk reset - right back to the 3 options screen.
Phil.
Hi Phil
Are you running the latest software version? There was a bug on the Leap Frog versions of ZerOS a little while back that could get the desk into this state. This was fixed in version 5.4.0, so I would suggest trying this version.
If you're already running 5.4.0, how old is your desk and have you replaced the battery recently? Again this can be a cause of these symptoms.
Peter Kirkup
  • 3 weeks later...
