Morning guys.
We currently have a frog 2 running 5.4.0.
Every time we turn the desk on, we have to reload our show from USB Drive.
Also, we regularly have a crash where we have to turn off and turn on and reload.
Is there a fix coming up for the reset issue?
Kind Regards
Marc
Evening Jon,
Yeah, any new shows we create, if we turn the desk off/on we lose it.
We have all our shows backed up on USB Drive so we can reload easily.
But it does get tedious reloading the show after the board crashes or at the start of the shift.
Hello, I had already reported the same problem on my
frog2 old model, I resolved to return
Release 5.3.5. Hopefully a new release that solves
the problem on our old desks (I have two
USB ports on front)
Piero
Hi Guys,
The new ZerOS software is not fully supported on the older Frog 2 consoles, as the hardware can't support it all.
There are two options to fully run 5.4: there is an upgrade kit available to replace the hardware inside the desk, or alternatively it's time to look at replacing the desk to a newer generation Frog 2, Leap Frog or ORB (soon, ORB XF).
Your local dealer can give you more information, including prices, for both these options.
Cheers
Hi All,
I have the same problem on a Leap 48.
Every time I turn it on it's like I've done a full desk reset - right back to the 3 options screen.
Phil.
Hi Phil
Are you running the latest software version? There was a bug on the Leap Frog versions of ZerOS a little while back that could get the desk into this state. This was fixed in version 5.4.0, so I would suggest trying this version.
If you're already running 5.4.0, how old is your desk and have you replaced the battery recently? Again this can be a cause of these symptoms.
  • 3 weeks later...
