BIG MAC Posted July 9, 2010 Report Posted July 9, 2010 Hi All This is my first post on this forum. This is probably a really easy question however, here goes. I have a Leap Frog 48 and have set up a 4 step chase (starting on channel 1 and crossfading into channel 2, then channel 3 and back to channel 2 and so on). However, I have set the speed of the chase at 80 for the 1st cue but I then want the chase to continue without stopping into cue 2 (the only difference in cue 2 will be that the chase will be slowed to 20). When I try to do this on the desk, everytime I hit the GO button cue 2 starts from the beggining at channel 1. How to I change this. Thanks in advance Chris
Jon Hole Posted July 12, 2010 Report Posted July 12, 2010 Sorry Chris - can I just confirm exactly what you want to do so I don't give you the wrong info?! You have a chase at 80 BPM (beats per minute). You then want to press 'GO' (Cue 2), and for that chase to slow down to 20BMP, but to continue 'uninterrupted'? Cheers, Jon Hole linkedin.com/in/jonhole
BIG MAC Posted July 12, 2010 Author Report Posted July 12, 2010 Yes that is correct Jon. I want to slow the chase down from 80bpm to 20bpm without it being interrupted. Cheers Chris
Jon Hole Posted July 13, 2010 Report Posted July 13, 2010 There is no way to directly change the speed of a chase by a cue. However, if you created the chase through the effects engine, you could then slow down and speed up the effect, which would continue to run uninterrupted, just with your new speed setting. Hope this helps to solve your problem? Jon Hole linkedin.com/in/jonhole
