masonpendrey Posted June 26, 2010 Report Posted June 26, 2010 I have spoken to Peter at ABTT about this and would just like to push it as this would so help me. Please could we look in to giving me a specials page that would give me a 1 to 1 dmx. It would just need to be 512 boxes on the touch screen, for each universe so i could just flash the dimmer. So when I go in to a venue with a show and they are not sure of their dimmer numbers I can just flash a dimmer without having to patch it to an empty channel to flash it. This would save a lot of time. It would be so nice to be able to use the command line to call up dimmers not channels, but I know this will never happen. The update I got to enable me to carry on using my windows remote lets me log on to the desk but when I try to change anything it loses connection with the desk and will not let me log on again till I have turned the pda off then on. Is this a desk thing or pda? It worked fine before the update. Many Thanks Mason Quote
Jon Hole Posted June 29, 2010 Report Posted June 29, 2010 Hi Mason, Thanks for your feedback. Please could we look in to giving me a specials page that would give me a 1 to 1 dmx. It would just need to be 512 boxes on the touch screen, for each universe so i could just flash the dimmer. So when I go in to a venue with a show and they are not sure of their dimmer numbers I can just flash a dimmer without having to patch it to an empty channel to flash it. This would save a lot of time. I've added this to the list for consideration in a future software release - ZOS-issue number ZOS-3087. It would be so nice to be able to use the command line to call up dimmers not channels, but I know this will never happen. Why not? Also added! ZOS-3088 The update I got to enable me to carry on using my windows remote lets me log on to the desk but when I try to change anything it loses connection with the desk and will not let me log on again till I have turned the pda off then on. Is this a desk thing or pda? It worked fine before the update. Added to the bug list as High Priority. ZOS-3089. Which model PDA are you using, and which version of ZerOS are you running on the desk? (Set Up > Files > Desk Information > Software Version). Many Thanks, Quote Jon Hole Global Product Manager, Systems and Control
masonpendrey Posted July 2, 2010 Author Report Posted July 2, 2010 i spent a few hours on the desk last night and the update Peter sent me has sorted it out. but not at first i had to go in to the pda and just keep playing around with it and touch wood it seems to be working now. but thank you for getting back to me mason Quote
masonpendrey Posted July 14, 2010 Author Report Posted July 14, 2010 just started to go over to tracking. is there any way of having an undo button for when i make my many mistakes. mason Quote
Kirkup_xp Posted July 16, 2010 Report Posted July 16, 2010 Hi Mason, If you enable the 'Show command line' feature under Special Page 2, you can use backspace to undo channel adjustment events. This will not, however, undo record/copy/delete/update actions. We have discussed adding a further undo function but this is still on the list for future consideration at this stage. I hope this helps, Peter Quote Peter Kirkup
