i have an zero 88 chilly pro 4-10hf and i have connected it to my pc com1 port using db9 connection which is then converted to rs 485 so i can connect to the dmx of the device.. when i am sending data using the cmd commands
mode com1:9600,n,8,1 to set the data bits etc ///
and
echo "@SC01:D01:LFF#">com1
i get data error from the device ....any ideas pls
Hi kbonnici,
You need to use a chilli rs232 node.
The sequence runs as follow:
pc > rs 232 node > rj 12 cable > dimmer rj 12 connection.
Without the node the network traffic will collide giving the error messages.
Part code 01-211-00 chilli RS 232 link. List cost £255.
You can purchase this via your local Zero88 dealer.
Hope this helps?
