Bilderbuch Posted June 22, 2010 Report Posted June 22, 2010 Hello, i´ve noticed that in Version 5.4.0 on Leap Frog 48 is a little bug. When you have selected several fixtures and open the the Effects Window to create a custom effect the descriptional text in the wheel LCD disappears (Size, Speed, Offset). No heavy bug but strange that this works fine on the Phantom. Then i have found a new "window". When you hold SHIFT and press a SUBMASTER FLASH Button then a window called "User definable Faders" and "User definable Keys" comes up. The User definable Faders seems to be the Submasters but the Keys are not useable. I think this feature is for the Frog 2 and Orb because i can not find any hints for this in the manual or release notes. Regards Bilderbuch Quote
Jon Hole Posted June 23, 2010 Report Posted June 23, 2010 Hi Bilderbuch, i´ve noticed that in Version 5.4.0 on Leap Frog 48 is a little bug. When you have selected several fixtures and open the the Effects Window to create a custom effect the descriptional text in the wheel LCD disappears (Size, Speed, Offset). No heavy bug but strange that this works fine on the Phantom. When I go back to the Demo room on Monday I will try and re-create this and log it on our report system - thank's for pointing this out. Then i have found a new "window". When you hold SHIFT and press a SUBMASTER FLASH Button then a window called "User definable Faders" and "User definable Keys" comes up. The User definable Faders seems to be the Submasters but the Keys are not useable. I think this feature is for the Frog 2 and Orb because i can not find any hints for this in the manual or release notes. Ahh you found the hidden window! Yes, this is carried through from the Frog 2 and ORB, and is of little use on the LeapFrog. Many Thanks, and I'll get back with more information next week! Quote Jon Hole Global Product Manager, Systems and Control
