Hello maybe I got something wrong, but can anyone tell me how to do this. If I for example program moving heads into memories and then continue to program only dimmers and store them into sub masters, then when I want to playback sub master the moving is playback as well, is there a way to keep them separate so I can use sub masters to playback conventional lights and memories to play back moving lights? I use leapfrog48 whit os 5.3.5
regards Tomas Carlsson
Hi Tomas,
After recording your memories, please make sure you clear the programmer (pressing clear a couple times) before you program your submasters.
Any attributes (pan, tilt, colour, etc) that are 'tagged' (the screen above the wheel is inverted when an attribute is tagged), will get recorded into a submaster.
I would guess that the moving lights are still 'tagged' from when you recorded your memories, so clearing the programmer will fix this for you.
Let me know if this doesn't work!
Cheers,
Jon
Jon Hole
