sgperry Posted June 15, 2010 Report Share Posted June 15, 2010 Anyone know why the floppy drive on our Fat Frog would not be working? I have asked one tech I know and he suggested bad ribbon cable, bad floppy drive, and/or bad circuit board. I replaced the drive with one that was working - no change. Attempted to try a different ribbon, but didn't have the right one. Not sure where to start or what to do in regards to the circuit board. When I say not working, what I mean is: I get a green light indicating the drive has power. I put a disk in, scroll through menu and choose format. It begins to attempt to format but never moves from "Formatting in progress 0%". Then after about 30 seconds it flashes "Error while formatting disk". I can eject the disk, put a new one in and try again and it just keeps giving me "Error while formatting disk". Again, I have tried three different working floppy drives. Any ideas? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
KWR88 Posted June 17, 2010 Report Share Posted June 17, 2010 Now being dealt with off forum Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
Studio111 Posted February 25, 2011 Report Share Posted February 25, 2011 hi, I'am having the same problems. I further can tell you that an fixture load stil works but formating, load or save a show will cause a error. Can you please help me solving this problem. Quote FatFrogUser Link to comment Share on other sites More sharing options...
Jon Hole Posted March 4, 2011 Report Share Posted March 4, 2011 Hi, Check that your Floppy isn't write protected, and maybe try a few different disks. If that doesn't work, give Keith a call on the number in his signature above. Cheers Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
