GKWide Posted May 22, 2010 Report Posted May 22, 2010 Is there anyway to change the settings for the UDKs on a per-UDK basis rather than defaults for times etc - ie being able to type [Time][3][uDK6] or similar to make it fade over that time rather than defaults? Cheers, Gareth Quote
Kirkup_xp Posted May 22, 2010 Report Posted May 22, 2010 Hi Gareth To do this you need to LOAD the UDK, then set the fade time, then update the UDK. We will be adding a better user interface to this in the future, but for now this is the best way to achieve what you want. Peter Quote Peter Kirkup
sirrus Posted June 1, 2010 Report Posted June 1, 2010 (Figured this might be the best area to ask my question without starting a new topic). What is the blank key in the programming keys section used for? (Left of the numeric keypad). It is unlabeled in the manual, is it awaiting a function or can it be used as a UDK? Thank you. Quote
