Roland Posted May 19, 2010 Report Posted May 19, 2010 Hi I have an Leapfrog 48. Is it possible to release f.ex ch 47 + 48 on preset row, and use them to control a Hazer without eny interuption when you play back the show or uses the clear button? Roland in Östersund/Sweden Quote
Kirkup_xp Posted May 19, 2010 Report Posted May 19, 2010 Hi Roland If you switch you preset channels into HTP mode then you can use them without affecting the show playback. This is done in SETUP / DESK SETUP / BEHAVIOUR / PRESET MIX MODE. I hope this helps, Peter Quote Peter Kirkup
