Hi
I have an Leapfrog 48.
Is it possible to release f.ex ch 47 + 48 on preset row, and use them to control a Hazer without eny interuption when you play back the show or uses the clear button?
Roland in Östersund/Sweden
Hi Roland
If you switch you preset channels into HTP mode then you can use them without affecting the show playback. This is done in SETUP / DESK SETUP / BEHAVIOUR / PRESET MIX MODE.
I hope this helps,
Peter
