Posted (edited)
We have an new LeapFrog 96 desk. Soft 5.3.5
We assigned 3 Mac 600 at the first 3 preset faders.
Fader 3 will not bring a DMX output at the program window (no value shown under the DMX adress like the first two ones).
But when you tag the MAC under the DMX value screen and use the wheel intensity it works fine.
We assigned the 3 MAC's once again but the same happend.
Any ideas to solve the problem?
Thank you in advance
Problem "solved":
Save the show to stick, delete all, reset desk, load show again.
The same happend at preset fader 1 some time later.
We tested to assigne a standard dimmer at the concerned fader it works also not. Seems like the connection lost between the fader and the "DMX register".
Edited by Jack_KTown
