ZerOS Software Version 5.4.0 Released
Zero 88 are pleased to announce the launch of ZerOS version 5.4.0 software for Leap Frog 48, Leap Frog 96, Frog 2 and ORB. The following are now available from the Support centre:
New desk software (ZerOS 5.4.0)
Offline editor software (Phantom ZerOS 5.4.0)
Version 5.4.0 includes a number of new features and bug fixes, and we would urge all users to upgrade to 5.4.0.
New Features include:
  • New Blind Mode
  • Support for the iPhone Remote (coming soon)
  • Tracking Backup Functionality
  • Support for the ZerOS Unlock Dongle for Phantom ZerOS
  • sACN Ethernet-DMX Output
  • LightFactory Playback Wing Support
  • Pan/Tilt Grid option in Position Palettes Window
  • Merge option where Overwrite is allowed
  • Dimmer Test Mode (ORB)
A full list of changes together with bug fixes are available in the Release notes.
Hi Peter,
In my old frog2 this release has one problem as version 5.3.0., That is after the reboot the desk is deleted everything (no show files, no fixture, no desk setup)
seems bug ZOS2947
Thanks on the answer.
Piero
Hi Piero
This could be related to the battery inside your console being flat - the battery on the motherboard needs to be changed every 2-3 years. This is a standard CR2032 type 3.3v battery, which should be available from most electronics shops. Can you try changing this (contact our Support number +44 (0)1633 838088 if you need advice on how to do this) and then let us know if this fixes the problem?
Thanks,
Peter
Hello Peter, thanks for the reply.
The strange thing is that with the previous release 5.3.5 this problem has never even occurred once occasionally.
This is a problem that I have already found in version 5.0.0 and 5.3.0 and later resolved with the release 5.3.5.
I will try to change the battery, hoping to solve the problem.
When the remote iphone will be available, it will be compatible with previous releases to 5.4.0 ......(when will available??)
Piero
Hi Piero
No, you will need version 5.4.0 to run the iPhone remote. We're pretty sure we fixed that bug in 5.3.5 so thats why i'm curious if maybe this is a slightly different issue like the battery running out. After that's checked, we can double check our changes!
Peter
Thanks for checking Piero - we've had another report of this from another Frog 2 user, so we're looking into a software fix for this now. I'm sorry for the delay in getting this sorted, we should have a fix soon.
Peter
  • 4 weeks later...
Hi Peter, I wanted to know if there is an upcoming scheduled release of software to solve problems reported.
Currently I use the release 5.3.5 that works well
Piero
This topic is now closed to further replies.
