lxkev Posted March 1, 2010 Report Share Posted March 1, 2010 Hi The Orb only makes 2 auto beamshape pallets for the high end system x-spots??? Quote I need a new job Link to comment Share on other sites More sharing options...
Kirkup_xp Posted March 2, 2010 Report Share Posted March 2, 2010 Hi Kev The problem with this fixture is that it has multiple modes that the gobo channel can run in, which are determined by the 'function' channel. As the ORB can't dynamically change these palettes, we can't reliably know that the palettes will work every time so we don't enter that data into the library. Sorry about this - you could always modify the fixture type to add the data for the mode that you use the fixture in, if that helps? Peter Quote Peter Kirkup Link to comment Share on other sites More sharing options...
