Conn Posted January 25, 2010 Report Posted January 25, 2010 When I have created a show in the phantom jester, how do I save it to a memory stick to use on the Jester? Quote
Kirkup_xp Posted January 26, 2010 Report Posted January 26, 2010 Hi Conn When you start up Phantom Jester there is a Settings button which allows you to configure the Local Drive Path - this is the location the software will treat as it's USB stick. Set this to the location of your memory stick (normally E: ) and then run Phantom Jester like normal. To save a show, hold down (by right clicking) on SHIFT and left click on MODE (this will put you in Super User / Setup, and then (after right clicking again to disable holding down SHIFT) use the menu and enter to select <Load / Save Show> and then <Save Show> and follow the prompts. I hope this helps, Peter Quote Peter Kirkup
