Hi guys,
for programming lots of different fixtures it is important to me to detag fixtures very fast - is that possible ?
Sebastian H.
Pro - Sound Showtechnik
Albert Einstein
Al Capone
You can also untag multiple fixtures using the same method as tagging them, ie press and hold down the first fixture selection button and then press and hold down another fixture selection button for approx. 1 second.
On the Mambo Frog you can untag all tagged fixtures by pressing and holding the Clear All button for approx. 1 second.
Bran Media | Myspace
Is there any way to have the clear all function on a Leap Desk ?
Sebastian H.
Albert Einstein
Al Capone
I can't think of an obvious solution at the moment :(
The Mambo Frog has two extra physical buttons on the front panel called SELECT ALL and CLEAR ALL which were added since fixture selection and tagging is spread over 4 pages of 24 fixtures.
