Haytech Posted January 13, 2004 Report Posted January 13, 2004 Hi guys, for programming lots of different fixtures it is important to me to detag fixtures very fast - is that possible ? Quote Sebastian H. Pro - Sound Showtechnik The secret to creativity is knowing how to hide your sources. Albert Einstein "You can get a lot more done with a kind word and a gun" Al Capone
KWR88 Posted January 13, 2004 Report Posted January 13, 2004 The only way to untag a fixture is to push and hold the fixture button until the Yellow LED stops flashing. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
K-Nine Posted January 13, 2004 Report Posted January 13, 2004 You can also untag multiple fixtures using the same method as tagging them, ie press and hold down the first fixture selection button and then press and hold down another fixture selection button for approx. 1 second. On the Mambo Frog you can untag all tagged fixtures by pressing and holding the Clear All button for approx. 1 second. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
Haytech Posted January 13, 2004 Author Report Posted January 13, 2004 Is there any way to have the clear all function on a Leap Desk ? Quote Sebastian H. Pro - Sound Showtechnik The secret to creativity is knowing how to hide your sources. Albert Einstein "You can get a lot more done with a kind word and a gun" Al Capone
K-Nine Posted January 13, 2004 Report Posted January 13, 2004 Is there any way to have the clear all function on a Leap Desk ? I can't think of an obvious solution at the moment The Mambo Frog has two extra physical buttons on the front panel called SELECT ALL and CLEAR ALL which were added since fixture selection and tagging is spread over 4 pages of 24 fixtures. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
