Sign in to follow this
LJ Kolbe
Leapfrog 48 USB Music Keyboard
Hi LJ
No, it is not possible. The desk does support MIDI notes so if you have a MIDI keyboard you could use that. You would need the SMPTE/MIDI upgrade card to add the MIDI ports.
I hope this helps.
Peter
Hi Peter,
Thank you for your fast reply.
I'll take a look at the backpanel. Perhaps the MIDI unit is allready built in.
Otherwise could you quote please?
I found a solution using DMX in and an interface MIDI->DMX.
Every MIDI note can be set to every DMX channel in one universe.
There are a lot of functions to form DMX signal. So I use a keyboard with keystroke and can dimm PAR channels :-)
Also submaster with shutter programmms for moving lights, 3 keys for RGB led tubes for flash effects and so on....
Now I'm able to do lights with my frog in a club the way I know from earlier times on an ALS ENIGMA
The name of the interface is MDX-65.
is there a way to use a MIDI note on signal (for example from a MIDI keyboard) for triggering submasters/memories? i cannot work with midi timecode on this one. but if i could trigger a memory or a submaster with a midi keyboard this would make my workflow so much more efficient.
Hi Johnny,
Yes - go to SETUP > Desk Setup and change 'MIDI Notes' from 'Disabled' to 'Channels', 'Submasters' or 'Memories'.
Hope this helps,
Hey Jon,
thanks for the advice. I've already done that, but still I can't figure out how to trigger memories via MIDI.
I went to setup > desk setup > and set midi notes to "memories"
when i go to my memory stack and to the trigger setup, i can choose between Auto, Go, Real Time, SMPTE, Midi. But in Midi I can only enter a MIDI timecode and not a note-on or CC value. where have I gone wrong?
the desk is a leap frog 48 with zerOS 7.4.0 installed.
Hi Johnny,
When enabled, the first note relates to memory one, second to memory two etc etc.
With 'Octave' enabled, each octave will do the same thing, meaning you can only access Memories 0 - 11.
With 'Octave' disabled, the second octave will start from memory 12 onwards.
Hope this helps,
Hi Johnny,
Hope this helps,
Hi Jon, I do not find this setting in the desk setup
Piero
Hi Johnny,
Hope this helps,
Hi Jon,
thanks for the explanation.
To be honest, I am somewhat disappointed by the limited functionality in this specific case. I'd rather be able to select which memory (or submaster) is being triggered by which note. Any chance of implementing this in future updates?
Thread-starter mentioned a way of using a MIDI>DMX interface. Do you have made any experience with these?
Thanks for the help!
Johnny
Hi Piero,
MIDI Notes is currently only available on the Leap Frog 48 & 96, and the Solution Series at the moment.
I get it! but why this feature is not present in the top desk?
Piero
We can definitely look further into this. I've added it as issue ZOS-5187
I've not had any experience of these, however other users on the forum might have done.
We're looking into this, to ensure features are spread across our consoles in a logical manner! However, I don't have a time frame for you at the moment, sorry.
