LJ Kolbe Posted January 22, 2010 Report Posted January 22, 2010 Hello all, Is it possible to use an USB music keyboard to toggle submasters/channels? Thx for your help Quote
Kirkup_xp Posted January 22, 2010 Report Posted January 22, 2010 Hi LJ No, it is not possible. The desk does support MIDI notes so if you have a MIDI keyboard you could use that. You would need the SMPTE/MIDI upgrade card to add the MIDI ports. I hope this helps. Peter Quote Peter Kirkup
LJ Kolbe Posted January 22, 2010 Author Report Posted January 22, 2010 Hi Peter, Thank you for your fast reply. I'll take a look at the backpanel. Perhaps the MIDI unit is allready built in. Otherwise could you quote please? Quote
Kirkup_xp Posted February 8, 2010 Report Posted February 8, 2010 Hi LJ If you contact your Zero 88 dealer who you bought the product from, they'll be able to provide you pricing on the upgrade card. Kind Regards, Peter Quote Peter Kirkup
LJ Kolbe Posted August 28, 2010 Author Report Posted August 28, 2010 I found a solution using DMX in and an interface MIDI->DMX. Every MIDI note can be set to every DMX channel in one universe. There are a lot of functions to form DMX signal. So I use a keyboard with keystroke and can dimm PAR channels :-) Also submaster with shutter programmms for moving lights, 3 keys for RGB led tubes for flash effects and so on.... Now I'm able to do lights with my frog in a club the way I know from earlier times on an ALS ENIGMA The name of the interface is MDX-65. Quote
Johnny Posted January 22, 2013 Report Posted January 22, 2013 Hello, is there a way to use a MIDI note on signal (for example from a MIDI keyboard) for triggering submasters/memories? i cannot work with midi timecode on this one. but if i could trigger a memory or a submaster with a midi keyboard this would make my workflow so much more efficient. Quote
Jon Hole Posted January 23, 2013 Report Posted January 23, 2013 Hi Johnny, Yes - go to SETUP > Desk Setup and change 'MIDI Notes' from 'Disabled' to 'Channels', 'Submasters' or 'Memories'. Hope this helps, Quote Jon Hole Global Product Manager, Systems and Control
Johnny Posted January 24, 2013 Report Posted January 24, 2013 Hey Jon, thanks for the advice. I've already done that, but still I can't figure out how to trigger memories via MIDI. I went to setup > desk setup > and set midi notes to "memories" when i go to my memory stack and to the trigger setup, i can choose between Auto, Go, Real Time, SMPTE, Midi. But in Midi I can only enter a MIDI timecode and not a note-on or CC value. where have I gone wrong? the desk is a leap frog 48 with zerOS 7.4.0 installed. Quote
Jon Hole Posted January 25, 2013 Report Posted January 25, 2013 Hi Johnny, When enabled, the first note relates to memory one, second to memory two etc etc. With 'Octave' enabled, each octave will do the same thing, meaning you can only access Memories 0 - 11. With 'Octave' disabled, the second octave will start from memory 12 onwards. Hope this helps, Quote Jon Hole Global Product Manager, Systems and Control
pierotec Posted January 25, 2013 Report Posted January 25, 2013 Hi Johnny, Yes - go to SETUP > Desk Setup and change 'MIDI Notes' from 'Disabled' to 'Channels', 'Submasters' or 'Memories'. Hope this helps, Hi Jon, I do not find this setting in the desk setup ??? Piero Quote
Jon Hole Posted January 25, 2013 Report Posted January 25, 2013 Hi Piero, MIDI Notes is currently only available on the Leap Frog 48 & 96, and the Solution Series at the moment. Quote Jon Hole Global Product Manager, Systems and Control
Johnny Posted January 25, 2013 Report Posted January 25, 2013 Hi Johnny, When enabled, the first note relates to memory one, second to memory two etc etc. With 'Octave' enabled, each octave will do the same thing, meaning you can only access Memories 0 - 11. With 'Octave' disabled, the second octave will start from memory 12 onwards. Hope this helps, Hi Jon, thanks for the explanation. To be honest, I am somewhat disappointed by the limited functionality in this specific case. I'd rather be able to select which memory (or submaster) is being triggered by which note. Any chance of implementing this in future updates? Thread-starter mentioned a way of using a MIDI>DMX interface. Do you have made any experience with these? Thanks for the help! Johnny Quote
pierotec Posted January 27, 2013 Report Posted January 27, 2013 Hi Piero, MIDI Notes is currently only available on the Leap Frog 48 & 96, and the Solution Series at the moment. I get it! but why this feature is not present in the top desk? Piero Quote
Jon Hole Posted January 28, 2013 Report Posted January 28, 2013 I'd rather be able to select which memory (or submaster) is being triggered by which note. Any chance of implementing this in future updates? We can definitely look further into this. I've added it as issue ZOS-5187 Thread-starter mentioned a way of using a MIDI>DMX interface. Do you have made any experience with these? I've not had any experience of these, however other users on the forum might have done. why this feature is not present in the top desk? We're looking into this, to ensure features are spread across our consoles in a logical manner! However, I don't have a time frame for you at the moment, sorry. Quote Jon Hole Global Product Manager, Systems and Control
