SR_BL Posted December 17, 2009 Report Posted December 17, 2009 i have a problem thats been in the last two software updates....i have had to work round this but i need to sort it before my next big event. whenever i assign RGB LED units to separate UDF's I get no output from the faders at 100%, i would like each colour to be independant of the intensity so when i put up a fader that i have programmed with green,it brings the green up from the UDF .... can i change any settings on the desk to alter that??? this isnt very helpful as i had programmed a few gigs in the past with RGB on seperate faders and now i cant do this... it was really easy and made programming extremely quick and simple is there a way to "grab" the intensity along with the colour so they will work independently, has anyone else had any problems in this area??? Quote
Kirkup_xp Posted December 17, 2009 Report Posted December 17, 2009 Hi SR_BL Have you tried untagging the 'other' colour attributes when setting up each RGB fader... eg: Set fixture to "Red" at 100% Intensity Untag Green & Blue (hold CLEAR and move each wheel, or touch on the touchscreen for the attributes) Record (without smart tag) <UDF> Then try SETUP + <UDF> "UDF Controls..." "Colour" OK Do this for each attribute and you should get the behaviour you're expecting. I hope this helps, Kind Regards, Peter Quote Peter Kirkup
SR_BL Posted December 21, 2009 Author Report Posted December 21, 2009 Hi Peter, that works but then the dimming curve isn't right. it also means that it takes a lot longer to program into the desk i really want to be able to grab just the R G B and put them on individual faders, does this mean i have to go back to previous Software?????? Quote
