aaron Posted December 16, 2009 Report Posted December 16, 2009 I have just discovered the shift copy feature for moving a part of the cue stack onto the subs I must say this is a great feature, But I have a few Questions 1. is there anywhere that you can see the cue number you are playing back 2. is there a way to step back (If not may a suggest Shift + sub key) 3. also it would be great to have a choice of where the fade times are taken from I.e a form of override would be great. so say you build a stack of positions with 1 sec fade but then want to busk a slow number you could then slow your steps to say 10 sec Great feature sorry about all the questions Quote
Kirkup_xp Posted December 16, 2009 Report Posted December 16, 2009 Hi Aaron The Range feature is really intended to be a basic 'cue stack' functionality - if you need the ability to manually override cues, to step backwards, etc, then both the Frog 2 and ORB desks will offer you this functionality. I hope this helps, Peter Quote Peter Kirkup
