  • 1 month later...
  • 9 months later...
I have just installed the PhantomFrog software and I notice that when emulating a BullFrog some of the high numbered A preset sliders seem to control the wrong channels. For example moving slider 48 causes the monitor to show 44 changing; whereas moving slider 42 shows 48 changing. If I am not in wide mode the B presets appear to work correctly, with 48 changing 48 etc.
Is there a fix or work-around for this?
If I took a chance on it and loaded a program from the Phantom Frog onto the real BullFrog I assume that it is the monitor which shows what will end up on real board rather than the sliders I actually used?
I am sorry if this has been raised before. I did look but I couldn't find anything :(
Infact the Phantom Bullfrog Preset A faders are muddled from 26 onwards. We'll put this on the list to be fixed in the next release.
Yes, it's what's on the monitor (not the sliders) that will be recorded.
Frog Reference No 5506 - On the Bull Frog version of the Phantom Frog the preset faders 26 - 48 are not mapped correctly to the output channels 26 - 48 - Bug to be fixed in next release of Phantom Frog.
Bran Media | Myspace
  • 1 month later...
I don't know if I'm mistaken here, but it seems to me the Fat Frog in Phantom Frog has one extra button? There is a button above the home button which doesn't do anything :? It doesn't have a label so I bet this is somewhat of a mistake. I'm not sure, does a Fat Frog have a fixture group button or not?
And check this one out:
click
happend while pressing the scene/chase button :?
Lost everything I'd programmed :evil:
This is indeed a 'phantom' button and shouldn't be there. It is a known bug in the Phantom Frog software. :oops:
Frog Reference 5471 - Phantom Frog (FatFrog mode) - Spurious Group button.
The Fat Frog desk uses the function button F4 as the Group button.
  • 1 month later...
Also has anyone noticed that Phantoms "Home" & "Select All" buttons are swapped!
This was an intreting moment when after using Phantom for so long on the laptop, then at 3 in the morning at the club on the real desk I hit what I thought was the "Select All" button to find all my punters blinded with all the lights including the show lighting (Dimmer rack) come on to full brightness!
I will never forget, Ever again, Where the "Home" button really is! :lol:
You sure it's not the "Home" and "Group" buttons that are the wrong way round on the Phantom Frog Mambo Panel?
Will be fixed in the next release :)
Frog Reference 5474 - Phantom Frog (Mambo Frog mode) - Home/Group buttons swapped.
