Carwyn Posted December 3, 2009 Report Posted December 3, 2009 is it possible that the solo setting on the submasters work across the whole desk rather than just the submaster section it soed not work on my desk what would i need to do to make it work Quote
chw Posted December 3, 2009 Report Posted December 3, 2009 MFK section: Special ->Flash Mode -> Solo Quote
Kirkup_xp Posted December 4, 2009 Report Posted December 4, 2009 Hi Carwyn If you set your preset faders mix mode into HTP instead of LTP (in SETUP / DESK SETUP / BEHAVIOUR) then soloing will also remove your preset levels. Any data in the program window (such as moving light intensities) will remain, as the program window overrides all other processing on the desk. I hope this helps, Peter Quote Peter Kirkup
Carwyn Posted December 5, 2009 Author Report Posted December 5, 2009 THE DESK IS IN HTP MODE AND I HAVE SET THE SUB FLASH BUTTON TO SOLO BUT WHEN I THEN PRESS THE FLASH BUTTON IT ONLY WORKS ON THE SUB SECTION WHERE I WANT IT TO WORK ACCROSS THE WHOLE DESK THANK YOU Quote
