HP Lighting Dude Posted December 2, 2009 Report Posted December 2, 2009 Can Phantom Frog be controlled via midi controller? I am interested in having a midi controller (ex. Jazzmutant's Lemur) control the Frog OS or Phantom. Can all parameters of the software be called up by midi? For example if I was to creat a control surface with a midi interface could I then tell it to control faders and buttons like on the physical console. My ideas is to have one midi control surface that can run the lighting software and my other software. I have had the Frog 2 console for about 4 years now and I am used to the software so I would really like to still use it for this application also. Quote
Paul Posted December 3, 2009 Report Posted December 3, 2009 Phantom Frog does not have any MIDI functionality. On the Frog desks, if the optional SMPTE/MIDI/CAN/DMXIN upgrade kit is fitted, MIDI timecode can be used to trigger timed memories in the memory stack. Quote
kgallen Posted January 3, 2014 Report Posted January 3, 2014 Hi Paul, Is it correct that the SMPTE kit can only be fitted to the larger Frog series desks? i.e. it *can't* be fitted to the Frog and Fat Frog? Thanks, Kevin Quote
Jon Hole Posted January 6, 2014 Report Posted January 6, 2014 Hi Paul, Is it correct that the SMPTE kit can only be fitted to the larger Frog series desks? i.e. it *can't* be fitted to the Frog and Fat Frog? Thanks, Kevin It can be fitted to the USB Leapfrog 48 & 96 and the Solution & Solution XL. By standard, it is already fitted into ORB and ORB XF consoles. Quote Jon Hole linkedin.com/in/jonhole
