When adding dimmer channels to other channels. We were trying to patch channels 33-40 to channel 24. After doing this these channels would come up on the intensity wheel. Is there a way to patch dimmers a different way? Or faster way?
Glenn
Hi Glenn
I would recommend using Edit Fixtures to alter the patch of the dimmers. To do this, press SETUP, then EDIT FIXTURES. Select the dimmers you want to repatch using the flash keys underneath the channels (the LED will light to show that the channel is selected). Now move to the PATCH tab on the monitor and set the patch using the on-screen controls (the DMX column and duplicates if required).
Once completed, press the OK button in the Edit Fixtures window to exit Edit Fixtures and then press SETUP to exit SETUP. Your channels will still be selected, so press CLEAR twice to clear the fixture selection, and then you are ready to use your new patch.
I hope this helps clear things up,
Kind Regards,
