I just updated from 10.9 to 10.12. have several problems. First when i reload a show that was stored in ver 10.9, when i press the edit button every light in the patch turns on. I found that clearing to the default was the only way to fix this. After re-entering the patch I was then able to go into the Edit mode without all of the dimmers coming on, however, the I am not able to edit the channels as i use to by pressing the flash button on then moving the fader to reset the level. Is there something i'm doing wrong?
