Studio111 Posted October 11, 2009 Report Share Posted October 11, 2009 Hi, I have my fatfrog now for 4 years and always worked with my effect (triangle, square .... ) Yesterday I did een reset of my frog and know when I program a movement it don't start. i know I have to set a speed and set a value on de Y and X parameters Is there another setting that I miss Regards Guido Quote FatFrogUser Link to comment Share on other sites More sharing options...
Paul Posted October 12, 2009 Report Share Posted October 12, 2009 Make sure the desk is running the latest software (10.12), so you're not getting tangled up in old problems here. Movement effects now stop if the master fader (Submaster or Playback X) is down, or if the Grand Master is down, or if Blackout is active. If you're still having problems, please attach a copy of your showfile and let us know which memory/submaster isn't working so we can look into it. Quote Link to comment Share on other sites More sharing options...
Studio111 Posted October 14, 2009 Author Report Share Posted October 14, 2009 hI I even have the problem when trying the create a palete . I'd store a effect on page 1 sub 9 show01.isf Quote FatFrogUser Link to comment Share on other sites More sharing options...
Paul Posted October 15, 2009 Report Share Posted October 15, 2009 For movement effects to work, you need to identify the Pan/Tilt channels under the Special setting in the Fixture Type Editor... Your showfile also indicates the desk is running version 10.9, I'd recommend upgrading to 10.12 so you're not getting stuck on old problems. Quote Link to comment Share on other sites More sharing options...
Studio111 Posted October 15, 2009 Author Report Share Posted October 15, 2009 Paul, That wasn't smart of me thx for the support it works fine know grtzzz Guido Quote FatFrogUser Link to comment Share on other sites More sharing options...
