I have my fatfrog now for 4 years and always worked with my effect (triangle, square .... ) Yesterday I did een reset of my frog and know when I program a movement it don't start. i know I have to set a speed and set a value on de Y and X parameters
Is there another setting that I miss
Regards
Guido
FatFrogUser
Make sure the desk is running the latest software (10.12), so you're not getting tangled up in old problems here. Movement effects now stop if the master fader (Submaster or Playback X) is down, or if the Grand Master is down, or if Blackout is active.
If you're still having problems, please attach a copy of your showfile and let us know which memory/submaster isn't working so we can look into it.
For movement effects to work, you need to identify the Pan/Tilt channels under the Special setting in the Fixture Type Editor...
Your showfile also indicates the desk is running version 10.9, I'd recommend upgrading to 10.12 so you're not getting stuck on old problems.
