lichtabtei Posted September 22, 2009 Report Posted September 22, 2009 Frog 2, v. 5.2.2. Can I change the fade times for all cues (e.g. the intensity parameter) if I already programmed the complete stack? I changed the default times in the setup menu...nothing happened. Otherwise I have to change the times for each cue in the "cue stack window-->"cue details" manually? Theres a trick, isn't it? Quote
