dappa Posted January 8, 2004 Report Share Posted January 8, 2004 ok I know that my previous Question did NOT make any sense what so ever. so let me try and explain a little bit better bare with me please. Im trying to set a squence without having to save 10-15 scenes. I would like to have my robotics move in squence yet flash one by one ..but heres the tricking part ...i would like to save all this onto a submaster... PLEASE TELL ME THIS IS POSSIBLE . AND also is it possible to set wheels at fixed values such as[(b] ;wheel 1color... wheel 2 pan wheel 3 tilt'') cheers again D.[/b] : : Quote Link to comment Share on other sites More sharing options...
K-Nine Posted January 8, 2004 Report Share Posted January 8, 2004 I think what you probably need to do is program a CHASE memory with the number of steps that you want and then transfer the memory onto the submaster. With regard to the wheels, if you edit the fixture personality data using the Fixture Type Editor (available on the Zero 88 website) you can reorganise the fixture parameters within an attribute (eg colour or beamshape). However you cannot have a wheel group that contains parameters from different attributes (eg colour, beamshape and position). Fixtures can only have a single brightness parameter which is assigned to the first finger wheel. Colour and beamshape parameters are arranged in wheel groups according to the information in the fixture personality file. With position parameters, Pan and Tilt always appear on the thumb wheel and first finger wheel respectively. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
