Hi, just wondering if it is possible on the Jester ML to colour mix LED's live. ie, one sub with red and intensity, next with green and intensity, and third with blue and intensity. This would entail the LTP value increasing and decreasing with the sub level, and not snapping (or fading) to the programmed level once 5% is achieved.
I tried this with the special button, modifying the colour fade attribute, but couldn't figure out what fade(V), and fade(D) meant!
If this isn't possible, would it be a possibility for a future release?
Thanks
If you've assigned the LEDs as fixtures, then you can't use the submaster fader to directly adjust the LTP value. This feature is available on the ZerOS desks (Leap Frog 48/96, Frog 2, ORB) though.
On the JesterML, to colour mix live you can use the wheels, or if you prefer to use the submaster faders, then just patch the LEDs to the generic channels rather than assigning them as fixtures.
