Ivan Posted August 20, 2009 Report Posted August 20, 2009 Hi, I'm not realy satisfied by the way the macros are working on the leap48. In the beginning they are fearly slow. And the biggest problem for me is that realy switched all lights screens and so on. Could be handy to create a layout of windows on your monitor. But if your running a show and you want to use the macro's to combine some positions and effects, it's not realy convenient that it switches other screens when you run the macro. So my question is, is it possible to have an option on a macro to make it 'silent' and is there way to make them a little faster. Kind Regards, Ivan Quote
Kirkup_xp Posted September 2, 2009 Report Posted September 2, 2009 Hi Ivan The Macro is recording button presses, so it does need to go through all of the steps to create the output you see. As for the speed of the macros, we will look at making this user definable in a future software release - some macros need to run slowly to allow the desk to catch up with the processing of commands internally. I hope this helps clear things up Kind Regards Peter Quote Peter Kirkup
