Ivan Posted August 20, 2009 Report Posted August 20, 2009 Hi, I have some problems with the effect window. First of all when you just press the effect button on the desk, and there are no effect parameters tagged, the wheel mode is still shown on the LCD. But when a parameter is tagged, the wheelmode disappears. Secondly, when you open the effect window, and adapt for example speed there with the keyboard, the new values are not applied to the effect. But if you then use the wheels it does work. But the problem with the wheels is that you can not adapt for example size for pan an tilt seperately. It should be able to do this by the keys on the desk or the keyboard. Kind Regards, Ivan Quote
aaron Posted December 11, 2009 Report Posted December 11, 2009 Hi I have the same problem Using Mac250 entours shift effects brings up the pallet window and i can start effects that way but when the effects button is pushed by itself nothing happens. the encoder windows don not change Quote
Laubfrosch Posted December 14, 2009 Report Posted December 14, 2009 Hi @ all, I also noticed that EFX attributes are not displayed as supposed at the wheels sometimes. But I am convinced the Zero guys will fix it as soon as possible. By the way the wheels work despite of not showing the attribute to edit. The second issue Ivan posted. Make shure "Smart Tag" is off. You may build a new efx with ony one attribute included than. "Smart Tag" on does tag ALL attributes by recording your "custom EFX" @aaron did you select a fixture or group of fixtures before you tried to playback a efx palette? Cheers Sven Quote Sven Paulsen Klangfarbe Vienna
aaron Posted December 15, 2009 Report Posted December 15, 2009 I tried both Funny Thing is this week with a fresh install and clean show the entours and fx's work fine But the mvs hazer is doing the same thing only in position encoder instead Quote
