I have some problems with the effect window.
First of all when you just press the effect button on the desk, and there are no effect parameters tagged,
the wheel mode is still shown on the LCD.
But when a parameter is tagged, the wheelmode disappears.
Secondly, when you open the effect window, and adapt for example speed there with the keyboard, the new values are not applied
to the effect.
But if you then use the wheels it does work.
But the problem with the wheels is that you can not adapt for example size for pan an tilt seperately.
It should be able to do this by the keys on the desk or the keyboard.
Kind Regards,
Ivan
  • 3 months later...
Hi
I have the same problem
Using Mac250 entours
shift effects brings up the pallet window and i can start effects that way
but when the effects button is pushed by itself nothing happens.
the encoder windows don not change
Hi @ all,
I also noticed that EFX attributes are not displayed as supposed at the wheels sometimes.
But I am convinced the Zero guys will fix it as soon as possible.
By the way the wheels work despite of not showing the attribute to edit.
The second issue Ivan posted.
Make shure "Smart Tag" is off.
You may build a new efx with ony one attribute included than.
"Smart Tag" on does tag ALL attributes by recording your "custom EFX"
@aaron
did you select a fixture or group of fixtures before you tried to playback a efx palette?
Cheers
Sven
Sven Paulsen
Klangfarbe Vienna
I tried both
Funny Thing is this week with a fresh install and clean show the entours and fx's work fine
But the mvs hazer is doing the same thing only in position encoder instead
