Fat Frog: Error loading show code 80300002 & others
>new Software 5.0 is already installed<
+While loading any saved show from Floppy the Desk stops
-Error loading show code 80300002-
all saved Data is lost an need to overinstall the OS 5.0 and set Fixtures new...
+also the Preset A doesen´t work ...
+also after some time the desk get slow or frezze the output - menue and Led´s still work ...
>Think our FatFrog need a service ? or OS failure ?<
Our Frog doesn´t have a VGA out ? - When the production/sale of the new Model (with monitor) started ? :cry:
Sounds like you have a very sick Frog. Was it OK before you installed software version 5 ? Does it get better if you re-install the version of software that came with the desk ?
All Frogs have been shipping with the monitor upgrade for quite some time now (since the middle of last year as I recall). If you have an older desk without the monitor output, then you can return your desk to the factory to have it upgraded. There is a charge for this service.
