Hi there. New Fat Frog user here! not sure what version software it is, i'll check up on that tomorrow.
Is it possible to program a single parameter (ie. prism, gobo, strobe) into a pallet? I could only record all beam-shape info.
Thought the desk was in partial mode but again, will check this tomorrow.
Hi Stuart
With the latest software, check that you have Beamshape set to <Channel> in the Partial Mode settings - this means you can tag each beamshape attribute individually. In <All> mode, all channels under Beamshape will be tagged together.
I hope this helps,
Peter
