andygwk121 Posted June 8, 2009 Report Posted June 8, 2009 Hi all im having a slight problem with getting personality on to the fat frog. the fixture file you down load from zero 88 is a .ift file but it wont let you edit it int he fixture type editor as its not editable by users. it also wont load in the commen fixture editor. and to get it on to the frog I need it in a Cft file. I have created the personalitys for 2 movers but I would like to beable to load the martin mini mac personalys off the downloaded fixture file from zero 88. as I need them on flopy for tommrow morning dose any one have any ideas? Thanks Andy Quote
Pickman Posted June 9, 2009 Report Posted June 9, 2009 Hi Andy, In the Common Fixture Manager you can have a maximum of 20 fixture personalities. If you go into the Common fixture template that you get when you download the Zero88 fixture library and delete some of the personalities that you do not require, by 'right clicking' and select 'delete', you can then 'right click' and 'insert' personalities that you have made. You can also 'insert' the appropriate personality from the Zero88 Library by selecting that file instead. Then save the file to your floppy and load it into your FatFrog. Hope this helps mate. Gordo Quote You can never have too much fun!
Paul Posted June 9, 2009 Report Posted June 9, 2009 You can assign User Fixture Types directly from a floppy disk without needing to create and load a Common Fixture Types (CFT) file. You can have your own fixture files plus the master library on the same floppy disk, the desk will ask you which file to use when you assign a fixture from floppy disk. Quote
tskm Posted April 10, 2011 Report Posted April 10, 2011 we would like to learn how to open ift expansion, can you recommend us a link which can help us please Quote
KWR88 Posted April 11, 2011 Report Posted April 11, 2011 PM on the address below and I will talk you thorugh what you need to do with this. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
Crazy H Posted June 20, 2014 Report Posted June 20, 2014 New to Fat Frog struggling with loading ELUMEN EIGHT as CFT have managed to load to diak but the desk is not recognising it. I seemed to have loaded LED 64's OK. NEED SUPPORT URGENTLY> Thanks in advance. Could it be that I'm missing something simple? iS A COMMON fixture file once you have imported it to the flopp[y Which format shouls it be saved as *cft or what? Quote
Jon Hole Posted June 24, 2014 Report Posted June 24, 2014 Hi Crazy H, Which Elumen8 fixture are you wanting to use? I can extract it and send it to you as an individual file which you can use straight onto your Fat Frog. Thanks Jon Quote Jon Hole linkedin.com/in/jonhole
Crazy H Posted June 28, 2014 Report Posted June 28, 2014 Have managed to get the Elmen Eight 9 channel onto the FF. I am now struggling with downing the fixture file for the AXIS 250 Moving Heads. Any chance that you can email it across. Cheers mate I'm just plodding and making progress Cheers H Quote
Jon Hole Posted June 30, 2014 Report Posted June 30, 2014 Hi, Do you mean this one? http://www.mega-lite.com/prolight/autoLight/axis250/ If so, here's the file for you: Axis 250.ift Regards jon Quote Jon Hole linkedin.com/in/jonhole
